Old March 1st 2003, 12:26
chigger chigger is offline
Other brake parts
I am just listing some options.
CNC has a larger MC which will bolt into a bug with an adapter they have, if you need one. They have two MCs one for drum brakes and one for disk brakes. The bore is 3/4 inch. I would say that is about the same as the one in the bug.
They also have the 1/8in NPT to metric bubble adapters if you are going with a proportional valve or wilwood calipers. This adapts the calipers and valve to the VW brake lines.
It took me a long time to locate these so I hope it helps some one. It was the last item I needed to finish my brake upgrade.
Old March 2nd 2003, 23:02
lightning bug's Avatar
Thanks Chigger! What did you pay if you don't mind?
Julian
'74 Super
Old March 3rd 2003, 12:50
Pillow's Avatar
Pillow Pillow is offline
Okay not on topic, but Chigger I think your e-mail has gone whacky. The past few e-mails I have sent keep bouncing back
Honest I try to reply.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old March 3rd 2003, 14:39
Adrian, I will send you another email tonight. The address is in the first part of the message between two <> looking things. I will also check back here to see if any problems.
Chigger
