Old March 30th 2003, 13:22
oldyeler oldyeler is offline
Remote Oil filter mount
I have not found a unit I liked as yeat . I was hoping steel with a built in vw bypass valve. I even have concidered aircraft units or having one made.
I am determeded to have one with a built in bypass I will go as high as $200. for a first quality remote plate I know that aircraft units are more than that,
This needs to be a good one
T-4. 2.0 w/t 36 hp upright DTM Going In a 356 Drauz , automatic , 1970 VW Kitkar pictures at Http//home.earthlink.net/~oldyelerbh2
Old March 30th 2003, 15:42
Bad bug's Avatar
Bad bug Bad bug is offline
Remote filter housing.
Have you tried gene berg as yet.
Old March 30th 2003, 16:02
Gene Yes . Cb yes CIP-1 Yes John at the air cooled web yes.and I am presently looking at a unit by AIRWOLF. filers for a Lithcom aircraft , ( excuse the spelling) but if is over $350 for there kit
Old March 31st 2003, 15:16
new question? how good is the amsoil twin filter unit it uses a primary and backup releif filter that is plumbed back to the case
Seems to me it should have been plumbed back into the the oil galley return line. to help maintain oil pressure.
Old April 4th 2003, 07:09
bren's Avatar
bren bren is offline
ive got a VERY simple and very cheap setup that works perfectly.. a regular scat mount, but fitted with a genuine VW golf TDI filter.
those tdi's see cold oil pressures as high as 150psi without bursting as the filter is heavy canned and has a built in relief valve..
works for me.. depends on your setup though i guess..
Old April 4th 2003, 16:00
Thank you Bren. I did settle on a filter mountwith a bypass From the air cooled net parts house. But if it is not to pricey. I will use the golf/rabbit desiel filter.
