Old June 20th 2003, 10:32
petevw's Avatar
petevw petevw is offline
oil pump leaking only when i turn off motor. why?
i have a oil leak dripping off the bottom left hand corner (opposite side of dipstick, left when looking at crank pulley) ONLY when i turn off the motor. in drips for like 3-5min then stops. when the car is running it does not leak. i can not understand why this is happening.
any ideas?
what should i do?
thanks,
pete
'72 super
'65 bus
'52 split
Old July 8th 2003, 11:01
CLKWRK's Avatar
CLKWRK CLKWRK is offline
Hey pete,
theres an oil leak on the suction side of the oil pump and/or galleys somewhere. when the pump stops-a-sucking, oil starts-a-drippin.
Bry
GL ghia restoration:
Old July 12th 2003, 09:31
MattKab's Avatar
MattKab MattKab is offline
Lightbulb
Try an anaerobic sealant like manufacturers use nowadays. It only cures where it needs to and the rest* magically disappears. No more gaskets
Old July 12th 2003, 15:03
Hello-
Good call - Loctite 518 is such a sealant. When I put in an oil pump, I use no gaskets - just this stuff. I put it also around the pump body to seal against the case. I make lots of oil pressure, and my cast iron pump body is turning orange from rust (i.e. no leaks :-).
Take care,
Shad Laws
Old July 12th 2003, 20:37
petevw's Avatar
cool, i think i have some at work. isn't it a flange sealant? i believe i used loctite 518 to seal a servo motor to a robot last week.
thanks,
pete
'72 super
'65 bus
'52 split
