Old August 20th 2003, 11:37
kenfyoozed kenfyoozed is offline
wanting to add wheels but have no knowledge
lok i had a 74 std beetle until a old lady killed it. im looking to get a super so i can do the german look thing. i want to add the new jetta wheels. are they 16 or 17? and what is the width? i saw post of where you either add spacers or trim the stub axle off the rear, for fit. looks easy. but what about the drivers front with the speedo cable? how do you go about this? i dont mind if the wheel sticks out from the fender a little.
also with lowering, how low can i go with lowered strutts? i cant afford maxx . can i lower it 2 inches and be ok? what about the steering linkage at this height? any probs? i saw were you might have to trim for it to work?
and lastly. with the tire size, would 195 -205 / 40-45 series be about right?
ok guys set me straight.
Old August 20th 2003, 18:25
TitoRay
OK, lets see where I can help. I believe if you want the 7" wide wheels, Maxx Struts are a must. 2-3 inches of drop is recommended. If you are going for a Super Beetle, check and replace all front end suspension and steering components as neccesary, especially if you want to avoid or fix the Super Beetle shimmies and shakes. The great folks at www.toplineparts.com will help you there.
As far as the wheels you want, I am not sure. I see so many different stock wheels coming with those Jettas these days.
As an example, on my car I have the Maxx Struts, lowered 2 inches, along with 17x7 inch wheels with an ET of 40mm, and 205/40 tires. The fit is PERFECT. No rubbing either way and the wheels look neatly tucked inside the fenders. On the back end, for me to fit my wheels and tires (same size as front), I had to flip a torsion bolt on each side--you'll know which one it is-- to keep it from rubbing/scraping on the wheel and tire. If you plan on lowering the rear end, you'll need to trim an appropriate amount off of the bump stops. Also, in order for me to get my wheels caps on, I had to grind down the axle stub a little bit.
So, once you find the size and offset of the particular wheels you want, go from there using this info and the rest that is to come from the others who have done the same thing. Oh, and you'll need to re-drill you drums for the appropriate bolt pattern.
Hope this helps. Hopefully I didn't make that seem to confusing and I REALLY hope my info is correct. Good luck, and keep asking!
