Old December 5th 2003, 17:40
63Rag 63Rag is offline
914 2.0,1.8,1.7 Con Rod compatability?
I just picke up a 2.0 case at the boneyard without heads and pistons and connecting rods. Can I replace the rods from a 1.8 or 1.7 motor Are all models the same in this respect.
thanks
Wolfy
Old December 5th 2003, 17:59
vujade's Avatar
vujade vujade is offline
I believe the 1.7 & 1.8 are the same because they use the same crank, but the 2.0 has different rods & they are usually more expensive if you can find them.
WinterJam 2010
Old December 5th 2003, 21:23
Wesayso's Avatar
Wesayso Wesayso is offline
the 2.0 had a different big-end size (=50mm as both 1.7/1.8 use a 55mm big-end) and with 131mm it is longer than the 1.7/1.8 con-rods (127mm)
Old December 7th 2003, 16:14
Massive Type IV's Avatar
The 1.8/1.8 crank, must stay with the matching rods.
The 2.0 was all by its self with both the crank and the rods
Jake Raby
Old December 8th 2003, 14:11
found them!
Just won a bid on ebay for the 2.0 rods. I also just got the heads from a 1.8 Ill have the valves opened up and port and polish and match the itake manifolds for a set of 40 webers. Next mission is to purchase a new set of 40mm Webrs
Thanks for input guys
Ralph
