Old January 16th 2004, 12:46
T4 IDF manifolds that reverse-mount the carbs
Does anyone make T4 manifolds that mount the carbs (dual) backwards so the idle jets point towards the center of the engine instead of outward ?
Or is it simply just a mater of taking them to a machine shop to reverse the flanges on the manifolds ?
I have a set of IDF replacement 48mm TB's that I want to mount but the injectors are towards the outside of the TB. If I could reverse them, it would make it easier to get to the fuel rail assembly. I'm using a FAT 911 setup so I have the room.
Thoughts ?
Old January 16th 2004, 15:02
Richie's Avatar
Richie Richie is offline
Hello,
Yes, the only one I can think off right now is Ahnendorp.
Cheers,
Richard
Old January 16th 2004, 15:58
danielzink's Avatar
danielzink danielzink is offline
If you know anyone that is halfway handy with tig welding and a bandsaw it's a pretty straightforward deal.
I had to have mine cut and swapped for the CB FI - if you look closely you can see the welds on the manifolds below the throttlebodies.
Dan
65 notch 2300cc type4
www.danielzink.com
Old January 16th 2004, 17:47
Thats EXACTLY what I was looking for !
Thanks for the pic Dan ! Now time to find a bandsaw ...
