Old February 22nd 2004, 21:18
yetibone's Avatar
yetibone yetibone is offline
Lightbulb Building my own Kafer Cup brace.
Hokay, I've sourced all the materials online to fab the bars out of hard aluminum pipe, and pieces to connect to the uprights out of 11mm ID aluminum pipe, and aluminum plate. I guess the ball-ends will be 1/2" stainless with a 3/8" hole. I'll make the chassis attach points myself.
I don't know the pipe measurements yet, or the actual size of the ball-end threads.
Yetibone
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 22nd 2004, 21:25
boygenius's Avatar
When I get mine in three weeks I'll give you the measurements.
Old February 28th 2004, 18:10
yetibone's Avatar
Thanks man! That would help alot. What I really need to know is the dimensions of the rod ends, i.e. the thread pitch, and diameter.
The tools needed are a right hand tap, to thread one end on each bar, a left hand tap of the same size, to thread the other end on each of the three bars.
That's about $35 for the thread taps. $35 for the aluminum pipe (16', hopefully enuf for 2 sets), and $120 for 6 stainless steel rod ends.
I can get all the materials online, and and the tools locally.
Yetibone
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 28th 2004, 22:01
Glad I'm not the only "I'd rather build it than buy it" guy around here.
Yeti, if you want to share those dimensions on the brace, I'll be happy to make you a pretty set of plans to go with them.
63 356b time capsule
948 project
Old April 6th 2004, 00:28
super vw super vw is offline
Any updates? I myself am thinking of fabing one up, maybe a parts list (exact size..ect of materials and such) from you guys who have done this... just to make life easier
Thanks!
Jonathan
Old April 6th 2004, 00:50
boygenius's Avatar
Main tube length is approx. 24" and the secondary tubes are approx. 8-1/2".
The thread size was 22mm X 1.5mm.
The tubes were 30mm OD X 20mm ID.
Each of the ends have 2" of threads.
Old February 9th 2005, 19:00
mattfaulkner mattfaulkner is offline
Did any plans ever surface from this? I have to do a project for a welding class I'm in, so I thought I'd make a kafer cup brace. Anyway, if anyone can reverse engineer some plans from an existing brace, I'd be happy to make them one. I promise it will be nice, too. I know if you already have one, you're probably not in need of another one. However, maybe you could use it on a future project. It'd be sweet for the whole GL community to have some real plans for the DIY kafer brace anyway. Thanks guys!
Matt F.
'71 1302
