Old April 22nd 2004, 19:37
73notch's Avatar
73notch 73notch is offline
master cylinder
just wondering if you need a different master cylinder if you upgrade to 4pot brakes on all four wheels. or will a stock 73' type 3 m/c work?
Old April 22nd 2004, 19:49
I have seen most people use the 944 MC.
Old April 22nd 2004, 21:08
73notch's Avatar
what would happen if i kept the stock master cylinder. what is involved in fitting the 944 master cylinder?
thanks alot,
ryan
Old April 23rd 2004, 02:45
boygenius's Avatar
i haven't finnished my brake conversion yet but from what I've read and heard you will have a longer stroke with the stock master cylinder than if you use a 944 M/C. I'm going to use a 911 M/C and all I will have to do is shorten the M/C push-rod a litle bit.
Old April 23rd 2004, 09:06
i don't know of anyone off the top of my head that stuck with the stock when going to 4-pots. do a search in the brake forum on here. there is quite a bit of info already out there with the comparisons. it is little effort to convert to a 944 m/c and worth it from a safety aspect. it was designed to handle the larger displacement.
Old April 23rd 2004, 15:24
Hi,
Well, that would be me..
I use the stock m/c and I have the even larger 4 pot Turbo Cup 944 brakes.
Thought that would only be one way to find out
The pedal travel is just fine, like stock. You didn't expect that one huh? Few people have actually tried this and then most people speculate and think of theories why it might not work and then if a lot of people do that, the theory almost becomes 'a known fact'
Fact is that the my front brakes now overbrake, which is not that strange.
Stranger is that people acually use the 944 m/c the way porsche mounted the brake lines in the front engined 944 the larger diameter side (21mm) to the front and the smaller diameter (19mm, also stock beatle) to the rear...That would worsen the situation IMO.
So, I still have to find the right m/c myself, but it might be a solution the reverse mount an 944 m/c or an old Audi one, as they seem to be the same (step cylinder 21/19mm) sort of...
Just my opinion on the matter
Greetings,
Walter
