Old October 6th 2004, 02:24
hawaiisurfer hawaiisurfer is offline
what size twists will fit?
i have a 64 11 window rag top bus and i am going to put on porsche twist wheels. can someone please tell me what sizes fit so that i know what to look for?
thanks in advance!!!
Old October 6th 2004, 07:45
vujade's Avatar
vujade vujade is offline
probably the easiest to fit will be 17 x 7 with a 55mm offset.
WinterJam 2010
Old October 6th 2004, 08:52
Panelfantastic's Avatar
Joe is correct. Nothing wider than a 7. You also may have to run a small spacer in the rear to position the wheel away from the spring plate.
Also, don't plan on lowering the front severely without having serious tire rub with 17's unless you run a reeeaaaly small tire.
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
