Old October 24th 2004, 19:45
Bad bug's Avatar
Bad bug Bad bug is offline
Rust be gone
Can anyone help me. I am in the middle of finishing my car and i found out that their was some rust under the paint work. The car was paint remove mechanically before. What was used to remove the rust and treat the metal was osphor can anyone give me a better alternative.
Old October 24th 2004, 20:12
justdubbin's Avatar
The only way to make sure you remove all traces of rust is by sand/media blasting and then painting with POR-15
Rob.
Old October 24th 2004, 21:03
rustbucket's Avatar
POR-15 is not necessarily the best option. It really depends on where the rust is. If it is under the exterior paint, do not use POR-15 or anything else like it. The only cure for surface rust under the paint is a quality primer. The rust needs to be removed, either mechanically or chemically, and then sprayed. If it is the pans, look at the POR alternatives. Eastwood sells a good one, and there are several more. I've used POR in the past and had mixed results. It is very prep intensive whereas others are not.
Old October 25th 2004, 00:49
boygenius's Avatar
Originally Posted by rustbucket
POR-15 is not necessarily the best option. I've used POR in the past and had mixed results. It is very prep intensive whereas others are not.
i have some issues with POR-15 not sticking to my chassis in places dispite hours of prep work. I have ordered some eastwood anti-rust paint and will be putting it to the test in a few weeks, hopefully.
Old October 25th 2004, 00:55
Bill K.'s Avatar
Bill K. Bill K. is offline
Right on rustbucket. Eastwoods Rust Encapsulator is good stuff. Just brush it on chassis/pan work and it self levels pretty well. You can buy rattle cans or spray it too. I had to remove some for welding and it took a lot to get it off.
For body work, have the rust stripped and painted with an epoxy sealer. Then filler, high build primer, paint. Careful who you have strip the paint -- you could end up with warp panels if they sandblast incorrectly.
Old October 25th 2004, 07:47
Bad bug's Avatar
The rust is on the quarter panel. I used osphor to remove it. Has anyone used osphor before.
Old October 25th 2004, 10:34
rustbucket's Avatar
I've never heard of it. I tend to shy away from chemical means. Too many factors involved to get a good result.
If it's the quarter panel, do some serious looking to make sure it is not rusting through the panel. If that is the case, then no measure short of replacing the panel will do. While replacing the panel, spray the inside of the body with an aircraft wax (Eastwood) or some type of undercoating. And be sure to get as much of the insulating foam out. That is the cause of the problem usually.
DO NOT use POR-15 or any other similar product on the outside of the car. There are numerous reasons, but the best is that it is a royal pain to sand it smooth. Almost impossible once it has dried.
