Rear wheel drive speedo
Any suggestions on how a speedo cable could be driven by the rear axle? Perhaps 1:1 gearing from the output flange.
I'm running 215/40ZR17 upfront (596mm) and the correct ~636mm diameter at the rear using 225/45ZR17. Any ideas? Matt |
Hi Matt,
You could always just get the speedo recalibrated for the new O.D. Regards, Andy
'55 oval GL 944T Calipers and discs front & rear. 17" Turbo rims 205/40 front, 215/45 rears 230BHP TIV fuel injected. IRS+Berg 5 speed box. Build in progress. |
The new VDO speedos use an impulse from a sender, you could stick some magnets on your cv to produce an impulse for the speedo. Steve C
Can the speedo be recalibrated?
I would like to use my stock speedo, as anything else looks odd in the 1303 'hole. I'll check the VDO website. Thanks, Anymore ideas? |
Most speedometer shops can set up a small gearbox to change the ratio to correct for different tire sizes. Not a big deal, it just fits between the speedo and the cable.
ken |
