Old January 29th 2005, 01:44
mattfaulkner mattfaulkner is offline
Super Suspension vs. Standard Weight
Hey everybody. I'm new to posting here, but I've been reading for a while. I'm very intrigued by the idea of making a type 1 outrun and outhandle a good handful of modern sports cars. I'm looking to get started, and I'm debating whether a standard or a super would be better. I've searched for information regarding this topic, but I haven't really found anything.
I've researched that a standard beetle weighs 198 lbs less than a super beetle. Now, would this difference in weight override any suspension advantage the super may have over the standard. As you all know, weight is a huge deal. At 198 lbs less weight, the standard will not only beat the super in the straightaways, but will also have less weight to lug around the turns. So...will this weight advantage be enough to cancel out any advantage the McPherson strut may have had? What do you guys think?
I'm tempted to say that a standard with independent rear and sway bars (though this would add some weight), would beat the super.
Matt F.
Old January 29th 2005, 14:54
i drive a standard, but the super is a better performing car all other things being equal. the weight is a factor, but the suspension is a bigger one. go super if you can. nothing wrong with a standard though. mine will spank most in the straights and turns.
Old February 2nd 2005, 17:17
oasis's Avatar
oasis oasis is offline
There is a 99 pound difference between a standard and Super of the same year.
Old February 2nd 2005, 17:53
Oh...I didn't think standards varied in weight that much. Maybe my figure I got of the samba was wrong too. Well, 99 pounds is a lot less than 200. If that's the case, the super is looking better.
Matt F.
Old February 2nd 2005, 19:09
Superman
Smile
The weight difference is debatable, I've seen it listed as, from 100 to 500 pounds.
I am very biased here but I know for a fact that the Super will out do a Standard in handling. When I was in high school, me and my best friend both had Bugs that were set up exactly the same. Mine was a 1973 Super, his was a 1974 Standard. We both had stock motors and a lowered suspension with aluminum wheels and 195/50R15 tires. My car would literally leave him behind by 3 to 4 car lengths in the corners and the smaller turning radius of the Super made it easier to maneuver overall. We would even switch drivers and get the same results.
The other factors to consider are... that the Standard has a wider rear track (like almost all pre-70's cars) and the Super has a wider front track (like all post-70's cars). The Super has struts (like 99% of modern car designs) and the Standard has torsion bars (0% of modern car designs).
I've said it many times before, the Standard is a great car for straight-line drag racing and the Super was made for autocross/corners.
Old February 2nd 2005, 19:12
Superman
Opps, forgot to mention the best part... the Porsche 924/944 suspension was designed based on the Super's suspension, that should tell you something there. That's also why the 944 brakes are so easy to adapt to the Super.
