Old March 28th 2005, 21:10
KAFUR1's Avatar
KAFUR1 KAFUR1 is offline
can any body translate this for me to english it is in dutch thanks
Old March 29th 2005, 19:38
Shadowbug's Avatar
a few years ago I did a translation from french that he artical was originally in, but I've since lost all copies of it.
a few pics of my project
Old March 29th 2005, 23:08
oasis's Avatar
oasis oasis is offline
Best I can do with a cheap translater .. I don't know Dutch:
VW Beetle disk brake convert divide to Porsche 944 disk brake
Bus for use of orginele outside Porsche layer. (16 x 17.41 & 19.02)
5 want to make this bus on the VW spidelas use to can of the orginele Porsche layer.
6 Furrow the placing of the naafring (FIG 4), first Porsche flens heat.
7 Place now the naafring (fig 4) in this later the standard VW layer comes.
8 Salad with help of a fitting slagbus the ring on its place now.
9 Place now the standard VW lower in the lower scale.
10 Assemble now the vetkering with help of a fitting slagbus.
11 Assemble now the thread ends for affirmation of the wheel nut.
Affirmations plate Porsche remkluaw on VW spindelas
Old March 30th 2005, 02:39
Richie's Avatar
Richie Richie is offline
Hello,
Maybe this helps:
conversion vw beetle brakediscs to porsche 944 brakediscs part 2
Sleeve to use the original Porsche outer bearing (measurements in millimetres)
5. Place the sleeve on the VW-spindle. This way you can use the original Porsche bearing.
6. Preheat the Porsche hub before pressing in the sleeve (fig. 4)
7. Press in the sleeve (fig. 4). The standard VW-bearing will fit into this sleeve later.
8. Now beat the sleeve in its place using a fitting pipe or similar.
9. Place the standard VW bearing in its place.
10. Put in the seal with a fitting pipe or similar.
11. Fit the wheelstuds.
Adapterplate for mounting Porsche callipers onto VW spindles
But you really need part 1 as well!
Cheers,
Richard
Old March 30th 2005, 16:39
Jeza Jeza is offline
I'm sure I've seen both parts around somewhere- are you sure its not in the germanlook galleries?
Just had a quick look and nope it ain't there... However I'm sure I've seen these instrutions elsewhere- perhaps someone else can shed some light.
1302 RAt "GermanLook"
Old March 30th 2005, 20:42
KAFUR1's Avatar
hey richie thanks alot i was wondering if you could do part one as well that would be cool... thanks alot bob
