Old April 27th 2005, 17:25
cormac163 cormac163 is offline
901 Gearbox
I am going to do a 5 speed conversion in the midst of a subaru conversion. Does the 901 use the Type 1 flywheel as the Subaru uses a modified vw flywheel will it fit.
Also how far or does the 901 box move the engine to the back of the car. If so how much by?
After considering if I should do it or not I have just bought the box AND I dont care too much about the fit I have read that it is a 3cm push back which make no difference as the rear valance will have to be removable and I can shave a bit more off....cant I?
thanks
Cormac
Old May 5th 2005, 16:45
Daggis Daggis is offline
Yeah, sure you could shave of some more, but do remember that moving weight backwards does hurt the handling of a already rear-heavy beetle..
Old May 6th 2005, 11:28
Porsche 901 cRADLE
I have read that the 901 box is 3cm longer so is that after the original mounts have been removed and the gearbox fitted.
What I can seem to find is a picture of the gearbox cradle with the 901 box in Place.
What i mean is if the gearbox is 3 cm longer will THE CRADLE BE MOVED FURTHER BACK?
Old May 7th 2005, 05:53
By moving the Subaru engine back it may not fit inside the stock body! There is a German kit which has a new slimmer nosecone which would allow everything to fit. They are working on a similar kit for teh 915 too
Rich
Old May 8th 2005, 07:43
Nosecone
Hi Rich
thanks for the reply. I was talking to Martin Bott after reading about the kits he was making for porsche boxes that was in Ultra VW. I have an older 901 box and he has said that he has a shorter nosecone for these boxes also.
Are you talking about the same guys the website is www.bugat5speed.de.
thanks Cormac.
Old May 9th 2005, 04:32
Yes, I was talking about Martin, I just forgot his web address!
There was quite a good article in Ultra VW showing the installation of a 901 in a bug chassis with his parts.
Rich
