Old August 18th 2005, 15:13
madpballer232 madpballer232 is offline
dry sump
what is the advantage.
possible on a type 4
will it help run my engine an cooler or would you still recommend plumming in a cooler.
any other info would be great
thanx carson
Old August 29th 2005, 12:07
rip's Avatar
rip rip is offline
check here for details
http://www.germanlook.com/Forums/showthread.php?t=5680
but basically a ds oil system is more efficient, it cools better as the oil is not "stored" in the engine, it frees up hp.
Old August 29th 2005, 12:12
rip's Avatar
rip rip is offline
what sort of cooling system you got now? upright conversion like the dtm?
if so jake says it is more than enough to cool the motor, but how big of a motor do you got?
The ds system has more advanages than just cooling, like it can eliminate oil starvation if you like the corners.
Old August 29th 2005, 15:05
Im interested in a dry sump setup maily to the really high temp during summer in greece. What dou you think of the pump from csp?
http://www.csp-shop.de/cgi-bin/shop2...kid=7330637214
The reason is that i could afford this kind of money in the next couple of months (along with tuition fees and living abroad).
If its not good i'll just stick to the cb ds pump and have a friend bring it over the US
Aircooled 4ever
1973 1303 going towards GL
Old August 31st 2005, 09:10
AFAIK, they are both the same....
