Old August 24th 2005, 03:33
tom'72's Avatar
tom'72 tom'72 is offline
will a bus trans fit the T1 flywheel?
have a Kennedy adaptor plate + flywheel to mate a subary engine to a type 1 trans but want to put a VW bus trans on it because they are stronger.
Will this fit the flywheel?
Old August 30th 2005, 06:01
tom'72's Avatar
nobody........?
Old November 15th 2005, 20:16
brujo65 brujo65 is offline
yes, T1 and T2 trans will work Ok
Old November 16th 2005, 14:15
Panelfantastic's Avatar
From what I understand, yes you can use the T1 flywheel on the bus tranny, the T1 is the smallest of flywheels and the bus tranny is the biggest of bellhousings.
It's when you try to use the larger flywheels (bus, T4, 228mm) in a T1 tranny that you run into problems. I've seen pics of the clearancing that has to be done to fit that big flywheel in that small bellhousing of the T1 tranny, it aint pretty.
Jeff-
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
