Old September 12th 2005, 08:57
Bad bug's Avatar
Bad bug Bad bug is offline
Swing axle to irs
This is not a suspension question, but i need to know if anyone has done a conversion from swing axle to irs chassis, has it worked out and what's the procedure to do this.
Old September 19th 2005, 14:22
ellobo ellobo is offline
Here's a link to some pictures I shot while converting my dune buggy.
http://www.netspot4u.com/~manxclub/albums/album91/
I fabricated these clip holding fixtures using an IRS pan as a template...
Hope it helps....
Old September 20th 2005, 08:48
Bad bug's Avatar
I have noticed when adding the conversion clips to the chasis they are angled inwards to the frame horns. Also was it necessary for you to grind away material from the clips before welding them to the frame.
Old September 20th 2005, 11:38
Apparently, I was sold clips that were supposed to fit a smaller diameter torsion housing... Just make sure you get the right ones. Because the extra grinding is a pain in the a$$...
Here's a another link that may be helpful...
http://www.blindchickenracing.com/How_to/IRSconversion/IRSconversion.htm
See the cut line in the pic...
Old September 20th 2005, 18:59
Bad bug's Avatar
Thank's alot this helped.
Old September 21st 2005, 09:14
Bad bug's Avatar
Does doing a conversion like this strengthen or weaken the chasis and where did you buy yours.
