Old November 13th 2005, 07:33
Backfiring at carbs
When I installed the 48idfs when new, idle was ok, but after a few days of driving, the carbs are backfiring! Could the idle jet be too small as I've maxed out on the present idle jet. Help?
T4 2666 1303s
Old November 13th 2005, 09:10
70Ghia 70Ghia is offline
Silverbullet,
Try this website, it might help.
I had the same problem too.
My friend Steve at Wolfgang Int. helped me out over the phone. Make sure the your linkage is set right after syncro is done. I know that every engine is different, Like mine is a 2.4ltr, 175hp and I'm tunned for Germany.
Good luck
Chris
AircooledVWAddiction.com- (Weber IDF tuning tutorial)
Old November 13th 2005, 11:05
Thanks Chris. Appreciate it alot.
T4 2666 1303s
Old November 13th 2005, 15:51
Bad bug's Avatar
Bad bug Bad bug is offline
70ghia what is the torque like on your motor. How fast have you driven your car.
Old November 13th 2005, 21:25
silver,
Is it backfiring throush the carbs? If so I would say your mixture is to lean. If it backfires through the exhaust then your mixture it to rich. try that and see what you get.
mike
Old November 14th 2005, 13:55
Thanks Mike, I've tried to make rich the idle jet as backfire when idle, but still there, I'll try larger jets.
T4 2666 1303s
