Old November 13th 2002, 16:32
havik180 havik180 is offline
full-flow oil system
I was just curious as to the pros and cons of the "bolt on" style full-flow system (the pump cover w/ the inlet and outlet) vs having the cases machined ? Is either better than the other or are they pretty much the same ?! I was also curious where an external oil cooler can be mounted (safely and effectively) on a Super ?
Old November 13th 2002, 20:58
Massive Type IV's Avatar
I don't like them at all, mostly due to machining problems and poor quality control....
They also put the filter directly in the flow of the hot air coming from the left cylinder bank...
They have way too many 90 degree turns inside them to keep flow up.....do it the right way or leave it stock.
Jake Raby
Old November 14th 2002, 00:00
Pillow's Avatar
Pillow Pillow is offline
I agree with Jake. Any decent motor should have the extra care taken to add a full flow system done right.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old November 14th 2002, 06:15
Oliver Knuf's Avatar
For an original or near stock engine it's a very nice bold-on item, as it's btw produced from Mocar for the Mexican beetles in 30mm with o-ring seal and high quality aluminum! For high performance, it's definitely not the best, as you also want to cool more and the hot air stream is not really senseful on the filter! Bore the case to get the inlet or use at least a pump with in- and outlet, even if the curves are pretty hard in such pump covers!
Click here to mail me!
