help me calculate fenderwith
here's the deal, I'm running stock type 1 discs up front , porsche carrera discs in the rear on a standard automatic chassis.
wheel dimensions: front=18x35x8,5 ET56 rear= 18x35x 10 ET50 (come from a Porsche GT3) I'm putting together a chassis with all of this, up front I estimate I need 30mm spacers on each wheel to clear the suspension and that would mean front fenders that are about 6 cm (+/-2.3") wider fenders. In the rear I need 2cm (+/- 3/4") spacer on each wheel to clear the torsion plate. I'm not sure but I think this way the rear wheels would need only very little wider then stock so my only option would be to get the front beam shortened. Am I thinking in the right direction here or completely off? What are your thoughts? |
up front i have 2" shortened beam lower spindles 20mm spacers 17x7 et 50 wheels and 30mm wider fenders and they fit , the spindles add about 10mm ,2"oversize fenders should be ideal for your application , ibelieve sandeep has the same offset wheels on the front of his beetle with a narrowed beam and 2" fenders , on the back i have irs porsche steel arms ,17x8.5 et 56 wheels with 255 tires 25mm spacers and 60mm over rear wings and they fit ok , i would be suprised if you could get those wheels under standard wings at the back ,i would just get 2" overs and spacer up to them
cheers jon
woop woop 67 2276 turbo 64 ghia 1776 zx7rr |
