Old May 16th 2006, 10:14
JefferyLawrence JefferyLawrence is offline
Ultimate Porsche Brake Upgrade
http://www.jeffsvwshack.co.uk/944turbo/
Click the above link for full details.
Old May 21st 2006, 04:43
I believe that for this sort of sales advertisement, there is the 'for sale' section...
Its BTW not the ultimate porsche brake conversion...
Old May 22nd 2006, 08:37
fastdub fastdub is offline
i assume 6 pot big reds would be the ultimate
but these would be pretty amazing for my needs
Old May 22nd 2006, 15:53
No, they weight too much! and even more so would the matching rotors. The 6-pots are the modern 'mono-block' calipes tho, so at least they are a little better already
Just trying to say that bigger brakes are not always better.
The ultimate race or street car just has enough brake for 99% of all occasions and is as light as possible to reduce (unsprung) weight...
Old May 28th 2006, 04:48
Typ Vier Typ Vier is offline
Wally wrote :
(No, they weight too much! and even more so would the matching rotors. The 6-pots are the modern 'mono-block' calipes tho, so at least they are a little better already
The ultimate race or street car just has enough brake for 99% of all occasions and is as light as possible to reduce (unsprung) weight...)
I think you should look at the weight of the original Beetle brake components first before making such a statement.
The original Beetle ATE caliper weighs 2900gr where as the Porsche 996 GT3 6 piston caliper weighs 3750 gr, thats only 850gr heavier.
O.k. the discs of a Beetle/Ghia have only 6400gr compared to the 9500gr GT3 units , but add these numbers up and you will find the weight gain at the front axle is only about 8 kilos.
Every brake upgrade will add weight no matter what you do but the Porsche components will at least have enough brake for 100% of all occasions no matter how big your engine or how hard your driving style will be.
Andreas
Old May 28th 2006, 07:12
Presuming that I didn't isn't trustfull either
My alu 944 turbo Cup 4-pot caliper weighs twice a much as a original steel bug one...
"The ultimate" brakes should be just enough for all situations. Then you have less overall weigth at all situations and less unsprung weight as compared to overkill brakes...
Like I said: too large brake components hurt performance overall...
