Old August 22nd 2006, 20:42
madpballer232 madpballer232 is offline
ball joint
are there any ways around using the kercher ball joint on my 1303 when going to 944 brakes? my budget is a little tight. my other question is it ok if i go with the 944 rears and giah up front. i bet it will be pretty unproportional but idk
Old August 25th 2006, 17:13
bt1211 bt1211 is offline
It's OK to use Ghia disk upfront and 944 rears. The brake pedal might be a little low for you but you can change to a MK1 MC(rabbit) 76 to 83. The mK1 MC has a slightly large bore. I dont have the correct measurements, Ill look for them.
Lanner at www.vdubengineering.com agreed with this.
PS.
He is "the man" when it comes to 944 conversions. Buy some of his stuff!!!!
Bryan
Old September 3rd 2006, 14:54
64bug's Avatar
64bug 64bug is offline
I believe its a 18mm mc.
Old September 4th 2006, 03:44
stock bug m/c is 19.05mm, there are a variety of watercooled VW ones that are bigger and will bolt in, a friend used a Mk3 golf which was 20.64mm with his 944 rear bug disc front
Rich
