TopLine to MkIV conversion
I have TopLine disk brakes on the front and rear. They are studded to a 5x100 bolt pattern.
What would I have to purchase and do to convert the front brakes to a Golf/Jetta (A4) system? I am content at keeping the rear brakes as they are. I am guessing I will save 0.08" on the offset from what your Web site says. Saving that plus not needing a 6mm (0.2364") spacer by using a 4th generation wheel on a 4th generation hub should move my wheels inward about 5/16" on each side. Feel free to respond here or in a reply to my May 8th e-mail. Thanks. ![]() Edit: I deleted a section of text which serves no further purpose. -oasis
(2004-2008): 1971 1302 w/2056 Searching for a new project ... Last edited by oasis; May 26th 2007 at 12:09. |
I think Lanner would be your best source for parts needed, or at least his ideas.
That's why I posted here and e-mailed him several days ago. I will try to call if I get a chance at work.
(2004-2008): 1971 1302 w/2056 Searching for a new project ... |
Sorry, took a Texan trip last week.
Seems like the easiest fix is to get rid of the spacers by machining up some low offset hub caps so that it works with your wheel combination. Or ditch the stock bearing caps, and apply a thin bead of silicone when you mount the wheel. The wheel (with the wheel cap) will sufficiently seal the dust out. You can either then drill a square hole (drill and file square) into the wheel cap for the speedo drive, or make up something that can be glued to the inside of the wheel cap so the speedo cable does not protude through the cap. Changing the brakes seems like alot of work (and money) for a clearance issue. Lanner |
No apologies necessary; I figured it was something like that. I just posted here as insurance for me having the right e-address for you.
Thanks for the reply ... talk to you soon. ![]() Update: The clearance issues have been solved. I still might want to upgrade the front brakes at some point but a few other necessities will take precedence first. When I am ready, I will call.
(2004-2008): 1971 1302 w/2056 Searching for a new project ... Last edited by oasis; May 26th 2007 at 12:04. |
