Old October 18th 2007, 23:30
Hoghead Hoghead is offline
915 model nbr and speedo help please
I bought what was described as a rebuilt 1985, limited slip, 915 box sight unseen. Now that it has arrived in Thailand, I am not sure what I received
Stamped on the bottom of the box is:
915/6112 718 5747
What does this tell me?
Both flanges rotate in the same direction, so I am presuming a LSD - is this a valid assumption?
I do not see any sensor for the electric speedo and the only sensor is a switch on the nosecone. Is this a reverse switch?
Where does the speedo sensor go?
There is no lever arm on the clutch release shaft.
Does anyone have one, or what else can I use?
Machine work here is cheap, and I have bought the Aircooled.net hydraulic clutch kit only to find that it is LHD and will need a new MC bracket
What is so special about Swepco oil?
It is not available here and I was thinking of a synthetic gear oil
Robert
Old October 19th 2007, 14:16
Turbo Haraune2's Avatar
Turbo Haraune2 Turbo Haraune2 is offline
The switch in front if for rewerse lights
If you cannot make the driveflanges turn opposite directions its a locking or lsd diff inside
Old October 20th 2007, 00:27
I thought it is a reverse switch as it is plunger operated and simply on or off.
Any input on my other questions would be greatly appreciated
Robert
Old October 20th 2007, 09:21
Yes, its an original limited slip. I can tell by the model number
Please send it to me! :-)
Old October 20th 2007, 23:30
I have researched the box code part of my question, IE
915 = 915 box
61 = 911 SC (ROW)
12 = LSD
718 = 1978
5747 = sequential box serial number
The big problem is that this should be an electric speedo box, but the speedo hole is plugged. The plug appears internal?? and not a simple frost plug type that I can easily pop. See pic:
I need an electric speedo output - any ideas or suggestions?
Robert
Old October 21st 2007, 07:41
Autometer har a universal signal generator for speedo signal.
Gives out a square vave.
I use it coupled to the original speedo wire.
