Old December 17th 2002, 00:24
BergRace BergRace is offline
Post AN engine inparts for sale.
AN T4 engine, 1800, 85 hp DIN, from a 412 S.
Engine is dismanteled, and will be sold complete or in parts.
Engine is an original Volkswagen rebuild.
Two very good heads, 41*34.
Flywheel with support bearing for use in T1.
Two stock T4 heat exchangers with 4-1 header and oval quiet silencer.
One bearing frozen on crank.
Rusty cylinders, but can be bored for 96mm's.
Will be sold to highest bidder, or at my discretion.
If any interest, please reply to the address below removing the obvious.
BergRace@Chello.twat.no
P.J.Berg.
Old December 18th 2002, 19:13
Current bid's:
Two heads: 200,- US $.
Heater boxes: 75,- US $.
Flywheel: 70,- US $.
P.J.Berg.
Old December 20th 2002, 18:59
Flywheel and clutch is sold.
P.J.Berg.
Old December 26th 2002, 21:32
njv's Avatar
njv njv is offline
hello.
plastic air intake boot ? o well thought not worth a try!!!
neil verdon 66 sqr on irs.
Old December 27th 2002, 05:44
Sorry no plastic boot.
Following is sold:
Clutch
Flywheel
Exhaust (inkl. heat exchangers)
Heads
Carbs
Intakes
Case.
Only things left:
Tinware
Generator
Block heater 240V for the mysterious second drain plate!
Stock cylinders(needs boring).
Stock domed pistons(Can be saved if in a tight pinch, will need rings)
Air cleaner setup for dual carbs.
Cooling fan with pulley
Crank 66mm (will need turning)
Rods.
P.J.Berg.
