Old April 16th 2009, 11:16
bamberjim's Avatar
bamberjim bamberjim is offline
Turbo Question
I have a Type 4 2l with porsche cooling at present running a E grind eurorace cam fitted, and have picked up a blow though turbo system (T3 into twin 36 Drla's) will this be ok with this cam.
Also has anyone got any pics of the exhaust header/manifolds as mine was on a bus before and will need mods to fit in the bug, need to see where the turbo is mounted etc.
any help appreciated.
also need to know
what fuel pump and regulator reccomendations
Old April 18th 2009, 17:13
I don't know anything about draw-through, but an E-grind is pretty mild AFAIK (its a low letter in the alphabet) (sp?). Any mild cam will work fine with a turbo engine so you should be ok with that part.
