Old July 4th 2009, 05:06
RUBYPARTS RUBYPARTS is offline
17" 4/100mm
Here is my acr with both wheel set one is the LENZO EAGLE 17x7.5 4/100mm
and the kyowa 17x7.5 4/100mm.
Old July 16th 2009, 08:52
Rob's Avatar
Rob Rob is offline
Looking good!
What's the offset on those rims and where did you get them ?
Are you running spacers ?
Thanks,
Rob.
Old July 20th 2009, 15:10
the wheels
the wheels are from local wheel shop in israel so you can find them in the internet. from where you are?
the offcet i can check for you tommorrow but with these wheels from the front i have real problem you short turn that stock wheels so you cant do a u turn once.
i don`t have spacers at all i am running 4x100 disc brake kit in the front and the rear is 4x100 drums.
if you want to put spacers you should have wider fenders, i have stock at the moment and i am running 205\40\17 on front wheels, 205\50\17 in the rear wheels.
Old July 20th 2009, 16:42
Rob's Avatar
Rob Rob is offline
Thanks for the info.
I'm in Canada.
Can you get enough movement for every day driving, or does it limit the front wheels so much that it becomes a problem ?
Rob.
Old July 21st 2009, 14:25
I like the angel eyes, where did you pick them up, and are there projector lenses or are they standard H4 reflector?
Looking very good on those wheels!!!
Old July 22nd 2009, 09:54
Smile Angel eyes
The angel eyes are from fk headlights h4 reflector , they are for golf mk1 they fit on the car without modification .
