Old January 13th 2010, 03:57
graham's Avatar
graham graham is offline
speedometer sender
Hi not been on here for ages so happy new year and a huge thanks to all those responsible for keeping this site alive.
Now my question I am trying to fit an autometer speedo to my 03 I have 944 front hubs any suggestions and help would be appreciated
gee dub
Old January 13th 2010, 09:24
Silly question, is your speedo electronic?
Old January 13th 2010, 22:31
Drill a hole in grease cap. Use the VW cap as guide for hole size (a small file can square the corners of hole)
Old January 13th 2010, 23:10
Humble's Avatar
Humble Humble is offline
If your spindle is drilled for a an abs sensor you can use the abs sensor by grounding one wire and running the other to the speedo. Did that for the race car and it works perfect.
Old January 15th 2010, 02:53
graham's Avatar
sender
yes speedo is electric steve ,but I think these other members have sorted it thanks for that
gee dub
Old January 15th 2010, 22:50
Does your speedo use a electronic conversion module from the stock bug speedo cable? I was going that route, but I have something WAY OVER THE TOP now! (will show in a few months)
Old May 13th 2010, 12:13
owdlvr's Avatar
owdlvr owdlvr is offline
Rally cars run them on the undriven wheels (when that's an option) purely because wheel spin upsets the distance travelled and thus the notes between driver and co-driver. On AWD cars you can basically run them on any corner, though depending on your diff setup Front is still 'best'.
Regardless, thanks DWP (Dave) that CV ring / mount is exactly what I wanted to find for my project
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
