Old January 15th 2010, 15:30
WRX/Porsche Karmann cabrio 1303
this is my long term project that I initially bought about 5 years ago like this:
It was never going to stay standard, the original plan was to buy a solid car and stick a subaru engine in with some uprated brakes and suspension, staying with an uprated VW transmission to keep things simple...
First up, some decent adjustable struts for the front
and some 996 brakes all round
I then started having a poke around and what I thought was solid turned out to be an incredibly rusty car, these things rust from the inside out!
inside the sill!
front end:
So I decided to do the job properly and take the body off the chassis
New heater channels and cabrio strengthening panels underneath:
rear crossmembers:
front bulkhead:
Inner wings: I think you get the idea, lots of other repairs too!
As the body was off I thought I may as well go the whole way with it and upgrade it completely to take the power of the scooby lump (starting at about 300bhp). I also decided to go the whole hog with upgrading everything to be futureproof should I upgrade even more. This is all based around a Porsche 911 trans (G50, like the Ultimas use).
As you can see, it wasn't going to just bolt in..
So I started cutting!
There was too much removed from the framehorns for my liking so I started scheming up new stronger ones
which ended up as this:
I planned to cut out the sheet floors and build a perimeter frame for new ones which will be substantially stronger
I did not want a roll bar of any kind, I like to keep a stock-ish look
front end of the chassis looking rusty too so that came out!
I also needed to make provision for a hydraulic clutch so went with a fully adjustable pedalbox, I lowered the front section of the floor to keep things tidy
Old January 15th 2010, 15:31
ended up like this:
Made up supports for the 996 turbo sports seats:
and sorted the 911 shifter
engine in to sort out mounts
bought myself a beadroller and made up some new floors
painted!
body needed modifying to squeeze the trans under the back seat
inner body cut away for engine room/access using a vw bus engien access panel that I chopped down
here some may notice the engine has been moved forwards and up in the chassis to give more sump ground clearance and to make sure the big quad cam heads fit under the bodywork
I then found some wheels I couldn't say no to, 19" Porsche carrera sports in Cayman fitment, 8,5J front and 10J rears
they needed the rear wings modifying to fit
by 45mm
front wings were massaged to fit as well as pulling the front suspension in a bit
I also added an air intake for an enclosed cold air feed for the engine
to go with all this, I modified the dash to take Porsche 944 VDO gauges, it will be covered in leather to look OEM
stainless exhaust system made up
Coolant lines made up to run under the chassis
which feed a cosworth Pace radiator and chargecooler up front
That's most of the story so far! I keep my website up to date so if you want to see more details have a look at www.ricola.co.uk
It should end up looking more or less like this:
Comments and ideas welcome! Not finished yet, I plan to do the paintwork this summer when the weather warms up a bit... It's staying the same colour!
Rich
Old January 15th 2010, 15:40
Perfect!!! That's a great recap. Top notch all the way.
Old January 15th 2010, 15:50
Nice build. Love the pan work.
Old January 15th 2010, 17:58
Jim's Avatar
Jim Jim is offline
I'm very curious to see the final result...keep going Rich!!
http://www.bugaru.gr
EJ20 Suby Naturally Aspirated
Old January 15th 2010, 19:20
Xellex's Avatar
Xellex Xellex is offline
is it going to be much heavier than before with all that metal work?
www.vw1303s.com
Old January 15th 2010, 23:09
Wow I didn't know you had all that rust repair you've come along way! Looking good!
Old January 16th 2010, 07:11
Well the chassis tube is about 25kg, I'd say the rear end body mods probably balance out, then add the extra weight from the G50, subaru engine and cooling system... Not sure what it will end up as but shouldn't be too bad. The main thing I wanted was not to loose too much ground clearance and keep the chassis work hidden, while adding considerable strength.
One other main mod I will do is to add a shortened Kamei as everybody seems to rave about them so much! However, I don't like how they look so 'bolted on' normally, so I will cut it down and mount it to the body, keeping all the front valance panel and wings visible with the slightly shortened kamei below that in black, so visibly it should be fairly subtle. It should actually improve cooling to the radiator as well...
Old January 17th 2010, 16:11
Right, time to start finishing off the body...
Filter frame now welded into the body
Hooks up to the wing pipe nicely
Inner wing finished off, note angle along bottom edge for strength, I will make a brace off this down to the bumper mount on each side to strengthen the back end
I've half done the other side, it will be the same apart from having the 'filter' area as a removable panel for maintenance.
Old January 17th 2010, 21:23
Filter looks nice. What are you doing about water getting in?(or out rather)
Old January 17th 2010, 23:17
johnnyvee's Avatar
johnnyvee johnnyvee is offline
that is some nice work
Old January 18th 2010, 03:29
Jim's Avatar
Jim Jim is offline
This Vw addict is crazy
Old January 18th 2010, 14:20
Jak Rizzo said he doesn't have any problems with water in his similar intake and his is a daily driver. If I do, I will put a small drain tube on the wing side of the filter box...
Old January 18th 2010, 14:46
F-22A's Avatar
F-22A F-22A is offline
Been following your work on your website. Amazing job you done there and I love it. Good to see the body back on a pan and love the rear wing air scoop, very nice detail.
Old January 18th 2010, 20:30
I thought someone said something about it before, but couldn't remember
Build is looking good!!
