Old January 17th 2010, 16:27
dub_crazee's Avatar
'69 / '76 Germanlook Project
i started this project october 2008 - starting with a 1976 body and 1969 chassis. I started off with a 1976 beetle i had since i was 15 - and acquired a 1969 chassis to IRS.
a couple of pics before
First up was new heavy duty floorpans and IRS conversion with 944 Turbo a arms
with this being shoe horned in next!
The chassis has also received a couple of small repairs to the framehead, a hydraulic clutch set up a a bug@5 speed shifter
the clutch MC was fitted through the inspection hole (had to be slightly enlarged) and a hole made behind the throttle lever arm cover for access
i think this is a much better way of installing it rather than cutting a large hole in the top of the tunnel as suggested
Classic Car Revivals
www.classiccarrevivals.com
Old January 17th 2010, 16:39
dub_crazee's Avatar
The body has also received extensive work with 2 new heater channels, new front bulkead, 2 new a posts, 1 new front quarter, new front apron / wheel well and panel below the petrol tank. 2 new rear quarters, 2 rear cross members, new rear valance, new front scuttle, 2 boot floor repairs and a couple of small gutter repairs. All panels were NOS with the exception of the a posts (hookys) and the wheel trough panel.
The car was then completely stripped and sandblasted - the coated with kephos
and the man doing the blasting - alex from abs blasting
hopefully my gearbox mount will be finished this week so i may get that fitted- and im also starting to prep the bolt on panels this week.
Old January 17th 2010, 21:36
Those are some nice MIG welds on the IRS pivot brackets. Well, from the progress so far looks like this bug will be on the road soon then. I'm going to start some rust repairs on my bugs body pretty soon, doing alot of what you have done already. This is good inspiration for me, and others I'm sure! Keep it up!
Old January 17th 2010, 23:07
johnnyvee's Avatar
johnnyvee johnnyvee is offline
nice
Old January 22nd 2010, 18:53
dub_crazee's Avatar
Thans for the kind comments
. ive just received my aluminium gearbox mount adapters from a friend so the rear cradle is now bolted to the gearboxx - when we get some room in the workshop il get the chassis back down and finish fitting the gearbox.
at the moment im just prepping the bolt on panels for paint. not very interesting so i wont bother posting pics of that.
cheers
Deano
Old January 22nd 2010, 18:55
dub_crazee's Avatar
Wrernchnride from the looks of your build so far - the body will not be a problem for you - do you do it as a job also? im awaiting pics of your clutch slave cylinder install as ive still gota do mine Think im going to mount mine similar to Wally.
Old January 22nd 2010, 22:01
Thanks. The work is no problem...getting the time to work on it is though . This is not what I do for a living (wish I could). By trade I'm a industrial mechanic so must perform many types of repair and rebuilding. My slave cylinder install is on hold due to work hours, building my header, and a friends motorcycle I'm rebuilding the engine on.
Old January 23rd 2010, 01:11
Good looking project so far. Keep the pix coming.
Old January 24th 2010, 08:53
dub_crazee's Avatar
ive got loads of pics of the body resto - but didnt want to bore you guys with all of those.
yesterday my gearbox blocks to mount on the beetle cradle turned up and they work nicely i just need to get some countersink bolts but this is it mocked up. im going to bolt it in and then mock up the front mount which i have all the bits for it just need welding together!
i also ordered some 4cm wider rear wings from CSP which dented the bank balance somewhat! Hopefully my Kafer 5 bar set up from vdub engineering will be ready soon too! its all starting to come together
anyways more pics! Ally spacer blocks for the beetle mounts
blasted 944 turbo a arms - not sure whether to leave them bare - paint them, powdercoat them or anodise them. ive left an ally springplate cover outside to see if it oxidises
powdercoated goodies still awaiting new bearings/bushes etc from pelican parts before i can put it all back together
996 caliper and rotor. 944 front hubs and cb performance dropped spindles away for machining.
finally a nice upright oil filler for my type iv motor build!
offically started prep on my doors yesterday after removing the worn hinge pins. its going to be a slow process but it hsould be worth it!
Old January 24th 2010, 21:49
Looking great...it will all be worth it in the end (thats what I keep telling myself anyway )
Old January 27th 2010, 10:44
SteveW SteveW is offline
Dean
Who are doing the work on the hubs and spindles?
Cheers Steve
TIME Never enough - COST Always too much
Old January 29th 2010, 06:05
Carefull with those protruding bolt heads in your tranny bellhousing. They _may_ just hit the flywheel ring gear...
Old January 31st 2010, 06:22
dub_crazee's Avatar
thanks for the heads up wally. i will be using countersink bolts though as i said
this week i made several purchases that i probably shouldnt have as i'm fairly skint at the moment lol! my CSP wings turned up along with my order from pelican parts so i can now build up my rear arms. i also won a pair of 2.0l cylinder heads on ebay very cheap, and some 96mm barrells and pistons.
also this week i changed the door pins on my passenger door, prepped both doors and rear valance and got a coat of reface on them so im pretty pleased
Old January 31st 2010, 08:56
Oeps, must have read over that part...
Well, better safe than sorry
Old February 7th 2010, 13:48
dub_crazee's Avatar
ive dont a bit more on my bug - but mostly filler work which is dull as fcuk! and messy....but gota be done....especially as i want to to be as stright as an arrow!
both doors and rear valance are now in reface
and the passenger door has new door pins
i noticed my origional door has an audi logo on it - shows how late it is :lol:
decklid received the swiss cheese treatment also and is now ready for reface
quick pic of the barrles and pistons....anyone have experience of the aa stuff? is it any good?
also turned out the 2 litre heads i won on ebay were 1.8 heads.....which is nice!
