Old December 18th 2010, 22:31
vugbug71's Avatar
vugbug71 vugbug71 is offline
lifting maxx struts on car
trying to figure out a way to adjust my maxx struts without removing them, I guess some small spring compressors would do the trick but does anyone have any other tricks, need to lift the left side 1 notch.
I wish i didn't have to because I love the stance but the left front tire rubs
Old December 19th 2010, 09:35
Might try this iff you can facricate one.
http://www.germanlook.net/forums/showthread.php?t=10584
Old December 21st 2010, 02:46
vugbug71's Avatar
I figured out a shortcut! with zip ties!
carefully lift the car up by the lower control arm enough to take the wheel off, then lift it until you can get a jack stand under the solid part of the car. Then put zip ties around the springs and tighten them up. Use the big beefy zip ties and put 3 - 4 on the spring.
Lower the jack and you should be able to adjust the clips. once the clip is in position, jack the contol arm back up so the springs rest on the silver supports then cut or loosen the zip ties. Dont cut the ties before lifting the lower control arm so the spring is resting on its supports, otherwise it will shoot out and kill you or something!!
Old December 21st 2010, 06:30
evilC's Avatar
evilC evilC is offline
I'd rather keep my fingers intact! Zip ties are no way strong enough to ensure a safe adjustment.
Those Maxx struts are a poor engineering solution for an adjustable ride height. Everything relies on clamping a piece of wire between the strut body and the bottom spring pan - seating that wire is absolutely crucial. Also, machining a groove out of the strut body weakens it. Either the strut is too thin at each of the grooves or the basic strut body is much too thick.
It should however be possible to weld on a threaded sleeve that will both strengthen the strut and make it much easier to adjust for very little money.
Old December 21st 2010, 06:33
evilC's Avatar
Simple coil spring compressors such as http://www.halfords.com/webapp/wcs/s...egoryId_165469 are very common, cheap, safe and effective.
Old December 21st 2010, 10:13
Eatoniashoprat's Avatar
I found that with the maxx strut the spring is short enough that I can loosen the top strut center bolt on both sides, then raise the car up and there is no pressure on the spring, or if there is a small amount you can easily compress it by hand. You have to do both sides at once though so the sway bar lets both sides drop.
Then I'd leave the balljoint connected and just swing the top of the strut passed the fenders and can do spring changes or height adjustments in about half an hour. I've got 2" wider front fenders though so I don't know if that affects the strut being able to clear the fender.
When you're done and the chassis on blocks you can raise one side up at a time from the balljoint and guide the strut into the upper mount.
I would NOT RECOMMEND this though if you don't know your spring and strut lengths otherwise you might end up in a bad situation!
Mike
1302 EJ20 turbo
Old December 23rd 2010, 18:56
Joel's Avatar
Joel Joel is offline
I agree the zipties is not the safest option but if you use the really heavy duty ones and a minimum of 4 (I'd use more than that) you may away with it.
I've got a pair of those from my stock strut days.
The springs on MaXX struts are far too small in diameter and closely wound for those type to work
I got a pair of these and ground them down abit, plus also put a small hole through them so I could saftey wire as well.
