Old May 25th 2012, 00:49
effvee effvee is offline
Oil relief valves on a type one
Hi everyone, will someone please explain to me the setting on the AS-41 case, dual oil pressure relief valves pressure settings, thanks
Old May 25th 2012, 06:12
I've always bought genuine VW ones and used the Type 3 slug with the ring around it at the oil pump end
Old May 25th 2012, 20:24
Hi Steve, thanks for the reply. I have a friend that was able to find a machinst that can make him a new set of pressure relief valves (smaller). By doing this, the machinst is going to make a very thin sleeve of steel for the bore walls. He will keep the original pressure settings, or better yet add an adjustable on also. I believe somewhere in the past, I believe I read were Rimco use to open up the smaller side of the oil cooler for better flow. The problem with the Mag cases and Alum is expansion of dissimular metals. With the two same matals and there expansion rate I believe the oil pressure can be keep up and under control. If I can find a good enough seal at the cooler, I don't see why keeping 30psi will cause a problem. My friend said in the Bently manual the pressure settings were 17psi. The weak link is the oil cooler grommets. I think i'll also see if my machinst can mill a very small groove into the dog house adapter to seat the grommet on both ends. Thanks again.
Old May 26th 2012, 07:34
IMPI IMPI is offline
porsche did just that with the 944 engine look how they did it (thread is same on the relief valves
IMPI
Old May 26th 2012, 22:54
Hay, I would like to know more of what you have just said. The 944 pressure reliefe valves were sleeved? Who did it work out?
Old May 27th 2012, 11:51
Hi I havent actually found one to dissect but my thinking is similar to yours Porsche went from an almost identical to vw valve to this setup as shown in the link
Hope this helps:
http://forums.pelicanparts.com/porsc...e-o-rings.html
Armand
IMPI
Old May 27th 2012, 12:17
http://944foot2thefloor.blogspot.com...-oprv-oil.html
IMPI
Old May 28th 2012, 00:21
Right on
Hi, vey good information. I'll read it and and see what are the settings.
