Old May 12th 2003, 08:20
SACO hydraulic clutch
Hello,
I'am thinking of purchasing a SACO hydraulic set-up from www.vwispwest.com for my 915 box.
Is this company reliable and/or does anyone have any experience with this clutch set-up. They say its a bolt-in kit with master and slave cylinder plus all hydraulic hoses and connections. Of course some mods will probably have to be made for the connection to the 915 box.
Costs are $179,-- plus shipping. Since the dollar is quite low these days, the ease of such a set-up is tempting.
Walter
Old May 12th 2003, 09:17
Question
Walter,
I think Alex is running this type of setup ?
Old May 12th 2003, 10:29
Re: SACO hydraulic clutch
Hello-
Hello,
Yes. As Type 3 owners, Charles and I have done tons of business with them (they specialize in T3's). They are good folk.
Yes. I have it on my 923 box (basically a 915) in my T3.
Walter
It is a good quality kit, but it is designed for the T1, and definately needs some changes for the 915.
The master is fairly straightforward to install. One suggestion is that it might be easier to use two studs and nuts to install the master in the tunnel. Go to NAPA and get a pair of Ford exhaust manifold studs - they are M10, and have a small unthreaded portion right where you want it. You also may need to bend/grind parts of the clutch pedal stop(s) to get a little more pedal travel.
One major problem I had is clutch travel. The hydraulic clutch setup is designed to give just barely enough travel on a T1 to disengage the clutch. Remember that hydraulics are not a cure-all - leverage is still leverage, whether mechanical or hydraulic. So, it is because of this reduced slave travel that the master (i.e. pedal) feels less force.
This is a problem because the Porsche tranny needs a lot more travel than a T1 tranny! After messing around for awhile, I developed a setup that not only gives me enough travel, but also gives me a lot more ground clearance. The slave cylinder sits up on the right-hand side of the tranny. I welded a new loop to the clutch fork to put the slave's stud through (it was 2.25" from the pivot as opposed to the stock 5.5"). And, I flipped the whole clutch arm around upside-down - that's what gave me the added ground clearance.
I should take some pictures of this... it'd make a lot more sense that way :-).
Take care,
Shad Laws
Old May 12th 2003, 15:03
Hi Shad,
Thanks for the help and reassurance about ISPWest. I will probably get one and modify it as you described. I also need a front window rubber for my square, so I can get that as well in one package :-)
Your remark about taking a picture would be greatly appreciated, because 'welding a loop to the fork' doesn't ring a bell for me at this point (yet?). Also right hand side: Is that as seen from the front of the car?
Thanks,
Walter
Old May 12th 2003, 15:32
Hello-
Sounds good :-).
I'll snap one within the week. I can't get to a digital camera right this sec... sorry... but in not too long!
Probably a case of poor nomenclature by the guy who wrote it. Sheesh, what a moron... :-). Ignore what I said before, and I'll try again.
Basically speaking, the clutch _arm_ has two important features: a splined through-hole (the pivot point) and a fork (the attachment point of the clutch activation thing, whether it be a cable or a slave cylinder). I used the term 'loop' to describe a fork that didn't have an opening, i.e. went 360º around whatever it is attaching to (the cable or cylinder).
Now, there are three important things to note about these two features of the clutch arm. The first (and most important) is the center-to-center distance between them along the axis perpendicular to the axis of the splined hole. This is effectively the length of the lever arm used to operate the clutch, right? I'll call this the pivot length. My 923 clutch arm had this distance at about 5.5" although there are several variations of this arm for different applications, so YMMV.
The second thing is the vertical offset between the two. As stock, the fork is lower than the splined hole. While this is convenient if you are using Porsche's desired clutch cable location, you have a slave cylinder to fit, and a ground to watch out for!
The third thing is the direction of the fork. Porsche intended the fork to be used one way, so if you simply flip the clutch arm upside-down (just a circlip holds it in), the fork can no longer hold the clutch cable nut (or slave cylinder equivalent). This kinda sucks, because it'd be nice to flip the clutch arm around so you can position the slave cylinder far away from the ground.
Now, I quickly realized that there was no way I was going to get the travel I needed out of the slave cylinder to keep the clutch arm lever length at 5.5". So, I resolved to change it. Guess what I used for my 'loop?' A nut, of size 9/16" IIRC. I drilled out the center to get rid of the threads, and I was left with a nice, strong, and convenient little piece! I did some measuring, mocked it all up, ground a little bit away from my clutch arm, and welded on the nut at a center-to-center pivot length of 2.25". That over doubles the throw of my clutch arm. And it works!
I also chamfered the holes slightly. Because this loop is reversible, the third condition above goes away - it can be flipped around. Ground clearance is now not a problem.
To hold the other end of the slave cylinder in place, I used another nut modified as above welded to a piece of angle iron and bolted to a couple tranny case bolts.
Once you see the pics, this will all seem very simple, and you'll wonder why it took me so danged long to figure it all out. It was an absolute pain the first time, but now that I know what's needed, I think a second time would be a snap.
Yes. The side opposite the tranny's side cover.
One more thing about the kit: I found that if you simply install the master cylinder as intended, the plastic fluid line wants to rub on the clutch pedal arm, and that's not good. Be sure to modify the system before installation to hold it out of the way.
Take care,
Shad Laws
Old May 12th 2003, 16:08
Thanks Shad,
It makes much more sense now. I love your self-irony tho.
I didn't know you had bought this set as well. Funny how we seem to like the same things and the solutions to the difficulties we come across...(type 3's, type 4 engines, T4 heads, Nickies, now this hydro clutch)
Thanks again for sharing your learning process, so we don't have to walk thesame difficult road.
Walter
Old March 9th 2004, 07:21
915 install
Hello (again),
I thought to dig up an old topic, that now has become more actual for me:
I 'am trying to install the saco hydraulic clutch to my 915 trans.
I have fitted a type 4 short block with KEP flywheel and stock 915 clutch and pressure plate. Fits fine.
I the previous posts Shad told us about the clutch fork set-up, but he did it for his type 3 without transmission forks and with a Tangerine exhaust.
I will use a BAS exhaust and have the transmission forks on my 1303...(!)
So the mounting position he suggests above wll not work in my bug.
I have seen the Remmele set-up from a far picture: they mount the slave cylinder perpedicular to the length of the car, but how they get away with the room for the 90 degree turn of the clutch arm is beyond me.
Does anybody know how what the best way is to set-up the slave cylinder on a 915 trans in a bug?
Thanks,
Walter
Old March 9th 2004, 11:50
GS guy GS guy is offline
I'd also be interested in seeing how you'd fit the hydraulic slave cylinder to a 901 trans. Shad's explanation is a little confusing with regards to flipping the clutch arm upside down? Not sure I'm following the explanation here.
I've got a similar problem with a 914 trans. Low clutch actuator arm meaning the slave has to sit below the axle shaft/CV joint area. Problem is I'm going to have some frame members in this area and there might not be room for the slave too. I definitely know the reversing pulley and housing (from the 914 mid-engine set-up) has to go.
Anyone got pics of a working set-up? Pleeeeease???
Jeff
Old July 17th 2005, 19:43
rip's Avatar
rip rip is offline
a couple of questions, I've heard many people using a solid line with this kit.
I had also heard that stock brake line will work; so what sort of adaptors were used to get it to work.
Also for anyone who has this in there bug how is the pedal travel?
rip's Avatar
rip rip is offline
Jeff
I seond that notion
Old July 17th 2005, 21:58
rip's Avatar
rip rip is offline
http://community.webshots.com/album/233555749GQyeIi
Old July 17th 2005, 21:59
rip's Avatar
rip rip is offline
