Old October 11th 2003, 09:11
brake switch
this info was in superman's article, but it had to be taken down and can't find the info in previous posts. what are you guys doing for the brake switch in a 944 conversion?
I have 944 m/c and am re-running all of the brake lines. so:
1. what part did you use?
2. where did you mount it?
Old October 12th 2003, 23:30
kdanie kdanie is offline
I think most folks are using a stock VW switch in a "t" fitting at the back, before the lines normally split. I'm going to mount mine near the shifter with the Bias valve and park lock (no parking brake in my 944 rears, they came from the midwest and the salt killed the backing plates).
ken
Old October 13th 2003, 21:49
i decided to go with a stock switch and t-fitting (using the same one that is used on the rear to split the line again) just off of the m/c so i can just run it back into the stock wiring location.
Old October 14th 2003, 17:08
MattKab's Avatar
MattKab MattKab is offline
Zen,
The increased efficiency of the Porsche brakes on a Bug gives rise to a normal braking* fluid pressure much lower than stock.
When I upgraded my brakes, I watched my voltmeter display the volt drop due to the brake lights, at a significantly reduced amount of pedal effort. Pressing the brake pedal minimally to light the back up when approaching a Junction in the dark required pulling up MUCH quicker than the car behind. This suggested to me the stock brake switch is rated at a pressure specific to stock VW braking system. I'm not the first to experience this??
I fitted a microswitch to a bracket secured behind the head of the top m/c bolt, an M8 bolt in 1" of fuel hose is cable tied to the pushrod and is adjusted to put the brake lights on when braking in rolling traffic, just like everyone elses.
The microswitch is wired in parallel to the pressure switch and are connected so that either serves to ground the coil of a relay for reduced load on the switches. Nothing is butchered on the car. The relay can take a shared feed from the brake/horn live at the connecters near the brake fluid reservoir (late Bug) and this is where the two core wire connected to the microswitch terminates. A few piggyback and male spades prevent any cutting.
Do not overlook the response of your brakelights for safety's sake.
Matt
Old October 14th 2003, 19:30
point well made and taken. has anyone else experienced the same? any other solutions? nothing wrong with the one made, just curious what others are doing too.
Old February 1st 2004, 19:31
kafer.chris's Avatar
kafer.chris kafer.chris is offline
Thumbs up me too
used a adjustable brake switch with a range of 0.5 < 5.0 bar bought from a local hydrolic suppliers same thread and there is a small screw on top to adlust the pressure..
jack up the front spin the disc get a monkey to eat peanuts and press the brake pedal till it binds on the disc !!!!
i used a contiuity tested as the light i.e....
when she bleeped the light was on adjust to suit the brakes
cost about £35 but worth it
am running 944 s2 brakes all round on a swing axle 72
chris
Old February 1st 2004, 19:58
boygenius's Avatar
What about a 911 master cylinder with the switches already in it. Shouldn't they be set for the correct pressure.??
Old February 2nd 2004, 15:28
MattKab's Avatar
I've just checked in the GSF catalogues, all Porsche models use the same switch for the brake lights priced at £2.00 (no partnumber given).
GSF sell a switch for all Aircoolers priced at £3.50 !!!
Maybe they are different? :shrug:
Matt
Old February 17th 2004, 17:32
great
thats going to save me a few quid for the cabrio brakes
cheers matt
chris
