Old January 18th 2004, 12:36
lightning bug's Avatar
spacers again
Where's the best place to get them? I'd like to use the bolt-through design. I'm running 17X7 front and 17X8.5 rear. Porsche Boxter wheels. Does 3/8"-front and 1" rear sound right? Thanks.
Julian
'74 Super
Old January 18th 2004, 13:44
NYBugman1972's Avatar
You have the exact same wheel and spacer setup that I have. I run a 1 1/4" wider fender in the back, stock in front and everything fits fine.
3/8" spacers are just goingto be a slip-on type. I bought mine from Topline. I bought my bolt-on 1" spacers from Tweeks, which is the Real Source for Porsche parts.
Mike Serrone
///BrooklynAutoRennen
Old January 18th 2004, 16:46
Werd. So do the rear spacers have studs already on them? And do I use the stock studs on the rear rotor? Thanks!!
Julian
'74 Super
Old January 18th 2004, 20:07
The spacers have studs in them and they come with supplied nuts. Use the supplied nuts to attatch to your existing studs and the bolt the wheel to the spacer as normal. Make sure everything it torqued right and you're all set!
Mike Serrone
Old January 18th 2004, 21:02
Panelfantastic's Avatar
A bunch on ebay. Do a search on "porsche wheels". Spacers in every imaginable size.
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old January 19th 2004, 16:58
Sweet! Thanks alot fellas.
Julian
'74 Super
