Old June 18th 2004, 17:06
Bad bug's Avatar
Bad bug Bad bug is offline
Knock sensor
Hi Guy's
Is it possible to use a knock sensor from an modern day car on a t4 engine.
Old June 20th 2004, 01:43
Shadowbug's Avatar
I've heard of using a knock sensor ignition system from a 1.8L wcvw engine on a type 4. in theory should work great since its could be converted to standalone easily, in practice probably would be trouble, since the timing is not setup for the type 4.
theoretically all you'd need is the dizzy, box, coil and wiring from a '86-89 GLI or GTI probably need to have the dizzy turned down to slip into the type 4 block. and find a suitable place to mount the knock sensor.
a few pics of my project
Old June 21st 2004, 09:00
Originally Posted by Bad bug
Hi Guy's
I would say no. Especially not from any watercooled cars. Not even from other aircooled cars as the 993 models.
The software to filter out all other noises is very engine specific and tuning of that software very critical as you might imagine.
The only device that can handle an UnderHeadCammed aircooled engine would be the Safeguard, sold by aircooled.net IIRC, but BadBug, you drive that dragrace yellow bug with the huge (2,8 ltr?) oxyboxer don't you? Surely, you're aware of all this...(?)
Best regards,
Walter
Old June 22nd 2004, 08:39
Bad bug's Avatar
Knock sensor
No Wally you have the wrong Bad bug. I live in Jamaica.
Old June 22nd 2004, 20:56
yetibone's Avatar
yetibone yetibone is offline
Knock retard ignition control is not a stand alone system, but part of a total engine management system, like Bosch Motronic.
As Walter pointed out, the knock retard parameters would have to be taylor-made for a ACVW. Since ACVWs needs so much less total advance compared to many cars made today, there's no practical application to retrofit such a system from.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old June 23rd 2004, 02:28
Hi Yetbone,
This does look like a stand-alone system:
http://www.aircooled.net/new-bin/vie...GN0007&cartid=
Do you know it?
Greetings,
Walter
Old June 23rd 2004, 06:39
yetibone's Avatar
Yes that is. I should reiterate...
Using one from another vehicle, I.E. VW Golf or Jetta, wouldn't work as THOSE are not stand alone systems.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
