Old June 27th 2004, 04:40
72blacksuper 72blacksuper is offline
porshce 928 phone dials?
I have a set of 78' porsche 928 phone dials, their 16x7" they have 225/55zr16's on em. If i get disk brakes will they just bolt on? how will the tire fit be? is this a to big of wheel to go on there? Thanks for any help.
Peace,
Wil
Old June 28th 2004, 12:40
No one knows? Ehh... its not gonna be awhile till i get the disk brakes but i would kinda like to know if their gonna fit or ill start lookin for new wheels and tires too. It's my daily driver so I don't wanna switch over to the disks some weekend and go to put my wheels on and not have em fit, then not have a car to drive cuz the tires rub on everything or rims rub on the coils or somthing weird like that. Once again thanks for any help.
Peace,
Wil
Old June 28th 2004, 12:54
vujade's Avatar
vujade vujade is offline
is the car lowerered? How much?
Does it have stock width fenders?
Are you running stock springs or narrow ones?
WinterJam 2010
Old June 28th 2004, 17:35
Uhh. the cars pretty much stock suspension wise. The fenders are stock width too. Coils are stock as far as i know. Its a stock super but its gettin there, its a 72' super beetle if you need to know that i dunno?
Peace,
Wil
Old June 28th 2004, 19:02
I too have a 72 Super, and I am running 16X6 C2's with 205/55/16's in back and 195/50/16's up front. I have the Topline MaxxStrut up front to clear the bigger wheels, I had to remove about 1/3 of the rear bump-stop cup. I am also running 3/8 spacers on all 4. I had 205/55/16's on the front but had a slight tire rub on the left front fender in a hard right turn so I went to a 195/50. Without the MaxxStruts on the front I could not get the wheels on the car. I could maybe have used the Sport Spring and an Adjust-A-Strut but it would have been close. The Phonedials are the older offset I think if so you would skip the 3/8 spacers.
Old June 28th 2004, 19:30
vujade's Avatar
phone dials came in both offsets (23mm & 52mm)
if they are 23 you can skip the spacers and you probably wont rub on the stock springs.
if they are 52, then you will need a 3/8" / 10mm spacer and a narrow spring like the Maxx struts, Kerscher struts or adjusta struts with sport springs.
otherwise you will probably need a 1" bolt on spacer to clear the springs.
WinterJam 2010
