Old July 1st 2004, 10:41
6x16 Fuchs under stock front fenders???
Anyone running 6x16 Fuchs under stock front fenders with a stock-width beam and CB drop spindles/discs? If so, what size tire are you using and what type of clearance issues do you have? I need to know before I can order my CCC fiberglass fenders...
Kafer_Mike
Old July 1st 2004, 11:19
vujade's Avatar
vujade vujade is offline
the wheels themselves will increase your front track between 1/2" to 3/4" per side depending on what offset stock wheels you have.
and the cb spindles/disc brakes will also add 1/2" per side.
so you will be increasing your track a minimum of 1" per side, so you can
either run a wider fender or get a CB 2" narrower front beam.
WinterJam 2010
Old July 1st 2004, 13:01
I was hoping they would fit under stock width fenders without much work. Oh well. Looks like I'll be cutting the beam...
Kafer_Mike
Old July 1st 2004, 13:31
vujade's Avatar
a 1" increase may still be inside the stock fenders.
you may not be able to turn that well though if you are really low.
WinterJam 2010
Old July 1st 2004, 14:05
I looked at CB's site and their narrowed/adjustable beam is only $170. Ordering a new one and selling my old one might be the way to go. Have you seen one of the CB narrowed beams? How does the quality compare to the original VW beam?
Kafer_Mike
Old July 2nd 2004, 04:42
Check the offsets of your wheels first. The 16x6J has a big offset and I have seen plenty of bugs running these with no mods to beam or wings.
I ran these wheels on my speedster with 944 brakes all round with no problems...
Rich
Old July 2nd 2004, 08:44
vujade's Avatar
The CB beam is made by an OEM manufacturer in Brazil. CB just had them make it 2" narrower. It is not a cut & welded beam like the other narrow beams on the market right now.
WinterJam 2010
