Old August 1st 2004, 15:42
trigga trigga is offline
928 brake conversion?
my friend has a 1985 928 all it needs is a fuel system. thats all i know. i wanted to find out if i can put them on my bug? right now i have a 75 standerd bug( doin the hot rod look but this german look is sweet and might re-do my 75 or get a super)
Old August 4th 2004, 22:08
Superman
Some of the 928 brake componets (discs, calipers, hubs) are the same as the 944 and can be used. You'll need some 944 (caliper mount) parts for the rear.
Old August 6th 2004, 14:48
so i would need to cross referance part numbers to see or are u telling me that year would work but i would need the caliper mounts?
Old August 10th 2004, 20:13
matara's Avatar
matara matara is offline
Superman, any idea which ones are interchangeable. I have been trying to source 944 turbo hubs here in Australia, and they are impossible to find.
I have a friend who breaks 928's and has several front/rear axles including everything for various year 928's. do you think a hub off a 928 could be used?
Sydney, Australia
Old August 10th 2004, 22:52
Superman
My only experience with 928 parts are in the books, meaning that I have never actually had the parts in my hands to compare them. However, I have knowledge that the 928 and 944 used the same brakes (not the spindles but the hubs/rotors/calipers). What I see from the part numbers listed in the Porsche book is that they will interchange.
Old August 10th 2004, 23:35
matara's Avatar
Thanks Superman I will photograph some of the parts when I go over there and put up in a new post.
Not sure if I want to use the parts of this S4 here in Australia, as I think its cursed. Literally wrapped around a telegraph pole I think!
