Old August 9th 2004, 02:15
180hp 1.8t in Bug
Finally, its in. Next up the structural frame to handle the forces it'll be putting out.
http://www.geocities.com/volkdent/Engine_In.html
Old August 9th 2004, 02:53
boygenius's Avatar
WOW!!! That is way cool looking. How did you solve the axle problem. How are you going to rig up shift linkage or is it automatic. What are you going to do with all that space behind the fire wall.
Old August 9th 2004, 11:18
Rob's Avatar
Rob Rob is offline
Very cool.
I'd be very interested in seeing how you are going to improve the structure
around the engine...might be 'borrowing' some ideas from you
Rob.
Old August 9th 2004, 11:41
Kataplun's Avatar
Kataplun Kataplun is offline
oh great the link dosent work for me
Old August 9th 2004, 14:31
Axle will be a shortened stock MkIII version. Eventually I'm thinking O2M six speed, then I'll need custom axles. I'm using Porsche Boxter linkage for the shifter, it still has some kinks to get worked out. For the extra space, can you say "trunk!" or Boot if your from over the pond. Some space will be taken up by the exhaust, but I'll have quite a bit left over. Kataplun, click on Volkdent in the corner then look at volkdents homepage, then 1.8tconversion.
Old August 9th 2004, 15:05
that's pretty sick...and you may be too.
nice work!!!!!!! :agree:
Old August 9th 2004, 20:41
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Wow, that is a great installation. I will be curious how you will contain that beast with reinforcement. Looks nice, when do the rides start? You sure have a great place to start as far as turning up the wick also. 250hp is no problem for the engine. What are you doing to the chassis to take it?
Thanks,
Randy
Old August 10th 2004, 17:06
I'm going to use 1.5" round, 2" square, and 1 x 2" rectangular tubing. One of the major tie-ins to the stock chassis will be two 5/8" U bolts that will go around the torsion bar housing. Other points for pickup to the chassis will be frame rails I've fabricated that extend the length of the pan just below where all the bolts hold the body and pan together. This is 1x2" rectangular tubing with holes drilled into it to allow the use of Allen head bolts in the standard body/pan bolt locations. There will also be a crossbrace between the two frame rails that will be just about where the front of the stock rear seat extends. I'm going to mock the whole thing up in ABS plastic pipe, I'll take some pics then to get feedback from anyone who has a mind for this sort of thing.
Old August 18th 2004, 01:32
Got a 3" GHL downpipe in. It will ned plenty of modification, but should work really well. There is actually a factory cutout in the middle of the rear apron that will work perfectly for this monster.
Old September 1st 2004, 18:21
It's from a standard 2002 Jetta 1.8t. The tranny is 02A with a bolt kit, but I'll be upgrading to the 6 speed O2M you mentioned eventually. It will stay stock till all the kinks are worked out, then will slowly be built up to whatever feels comfortable, maybe in the 280-300hp range. As it sits, if I end up with an 1800lb car, with the stock motor this thing will do 0-60 under 5 seconds, so I'm not sure how much power will end up just being scary. I'm thinking APR Stage III setup, but we'll see. Exhaust will be a custom 3" based on a stainless GHL downpipe and cat. I'm thinking that 2 3" pipes sticking out of the stock location might be kind of sic.
Old September 1st 2004, 21:17
yellow73's Avatar
yellow73 yellow73 is offline
Just when you think you have seen it all...this should be wicked and the weight distribution should be great too.
Old October 4th 2004, 21:19
I've finally decided on a plan for the superstructure. It took many hours of head scratching, but I like it a lot. It will be composed of 2 major parts, one under the car, one inside the car, and then a roll cage and crossbraces will be bolted to it. AND I get to use my tubing bender, so that will be fun. I had a change of mind this weekend on the suspension. I decided awhile ago to go with the stock strut type setup, but was talking to KW Suspensions about building a shorty version so I wouldn't have to cut strut mounting holes through the inner fender well. It was a pain in the butt, so I decided just to go with the Variant III KWs and cut the hole. With the shorty version I was worried I wouldn't have enough travel, now I'll have plenty. So they are ordered up, got some of the high grade nuts I need, and soon I'll be warming up the MIG!
Old October 4th 2004, 22:11
vdubvr6 vdubvr6 is offline
that **** is awsome!! we all need more pics of the progress man!! :bowdown:
VdubVR6
'72 Std Beetle
'00 GTi VR6 (SOLD)
Old October 25th 2004, 00:56
Apparently I'll be recieving the complete engine harness this week. I was supposed have had it right from the get go, but getting these not-off-the-shelf parts from RPI has been a challenge. I did recieve all the grade 10.9 mounting bolt and nuts from Maryland Metric, some used half shafts I got for a song on Ebay, some tubing clamps for the superstructure, and the KW struts are supposed to show up in a couple of weeks.
Old February 12th 2005, 00:41
I recieved the 3" widened fenders that'll fit the 235/45/17s on the H20 platform from Creative Car Craft. I've read a lot of peoples comments on their quality, and I was not disappointed. They are amazing, the quality is phenomenol, the finish was perfect, the strength and build quality was amazing. IF ANYONE IS IS CONSIDERING REPLACEMENT FENDERS, WIDENED OR NOT, PLEASE BE ASSURED THAT CREATIVE CAR CRAFT WILL DEFINATELY MAKE YOU HAPPY. They are lighter and stronger than the steel counterparts, and won't rust or get dented.
