Old October 4th 2002, 09:24
Check this out !
VW dragracer turned hill climber.
Link to site : Here
On the 2.9L type 4 he's using the FAT upright conversion...look at the rear decklid in the pics....Does this mean that you can use the FAT conversion (No machining) but just have to modify the decklid a bit ?
Whoops...just read through the site a little more and it says the decklid was modified ( fibreglass) to clear the shroud..... Seems cheaper than machining the case.
Comments ?
Old October 4th 2002, 10:05
Alex's Avatar
Alex Alex is offline
Your decklid would require less modification since the older ones are flatter than the new ones. You would have to cut it so that you can close the lid. A way of hiding it was to have the rear license plate light mounted higher so that you could not see the cut if I remember correctly.
Old October 4th 2002, 11:24
Question
So it looks like you are saying it can be done.
I'm going to inquire about the kit and see what parts come with it. I really like the look of the 911 fan...just not keen on machining the case.
Old October 4th 2002, 19:44
love that blue color. looks like it has a lot of depth.
