Go Back   GermanLook Forums > General > Members Rides
Old January 1st 1970, 00:00
Jim's Avatar
Jim Jim is offline
Questions about Jims ride
http://www.bugaru.gr
EJ20 Suby Naturally Aspirated
Old May 22nd 2006, 08:23
TOW74 TOW74 is offline
Camber Adjustment?
Hello Jim?
Jim, what did you do to get more negative camber? I have put the 944 brakes on my 1978 cabriolet, but I have alot of possitive camber. I need some help, what ever information you have would be a big help.
Thanks, TOW74
Old May 23rd 2006, 05:18
Jim's Avatar
Jim Jim is offline
Dear Friend
There are several ways to face this problem..
First is came from Topline parts called Camber kit ++ which allows you to play +1 -1 positive or negative and installed in both sides of your control arms.
Second came from H&R and it's Triple C Camber Adjustment Bolts which allows you play on the upper of the strut 0-3 degrees, positive or negative.
As we speak write now I have the same problem 1/2 inch on each side and I have order both H&R and Camber kit to correct the problem, so when I receive the parts I will inform you if I have succed.
Try a quick search on Germanlook for camber kit this will help you.
hope that helps
