Old October 26th 2004, 03:32
4agedub's Avatar
4agedub 4agedub is offline
Type 4 2.7lt cooling
I just finished my 2.7lt type 4 running a scat crank, carillo rods and chevy forged pistons. The compression ratio is 13:1. Will a normal type1 cooling system be enough or do I need to go for a porsche type setup when running with 102 octane fuel?
My previous engine ran on 100% menthanol, the menthanol helped with the cooling so I was able to drive the car without any fan housing.
Old October 26th 2004, 09:47
rustbucket's Avatar
Preemptive strike:
Go over to shoptalkforums.com and check out the thread on Porsche setups. I think it's up to 7 or 8 pages by now.
It's YELLOW
Rolling on a daily basis.
Old October 26th 2004, 16:37
you will find a bunch of info here and on STF on the subject. some objective, some not. i have gone based on research and facts as much as possible. ran two systems and where i LOVE the looks of the 911 fan, i went with the better performer...a DTM.
Old October 26th 2004, 16:58
cnavarro's Avatar
cnavarro cnavarro is offline
A DTM will help, but cast iron cylinders (if cast iron), are the limiting factor, so don't expect much in the area of engine life. But I assume that's not a big deal considering it looks like a drag or race engine only based on it's fuel requirements. Is that the case?
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Old October 26th 2004, 17:40
Massive Type IV's Avatar
whew! at 13:1 You'll have head leaks with iron cylinders before it ever fires up without serious mods!
For that application I wouldn't think about doing any way other than with Nickies!
Jake Raby
Old October 27th 2004, 05:47
4agedub's Avatar
Thanks guys. Will check those posts out.
I want to use the engine in a toy. Drag racing every now and again, stuff like that.
Funny enought there is no cylinder leaks... guess I'm just lucky.
