Old December 11th 2004, 23:03
V8 bug
I am thinking about puting a v8 in a bug. It would be mid engine with a manual tranny to a danna 60 rear end. What year bug should I put it in? I am worried about the distance between the front seat and the center of the stock axle. I think if I use a porshe g40 transaxle I can eliminate most of my problems.
Any input would help.
Mike
Old December 12th 2004, 17:41
rustbucket's Avatar
Put it in a 53 !
It's YELLOW
Rolling on a daily basis.
Old December 13th 2004, 00:21
This should answer all your questions. It just happens to be in a Lambo lookalike, but your doing the same thing. Look at the Audi tranny.
Old December 13th 2004, 00:22
Ooops soorry. Forgot to paste!
Lambo Lounge
Old December 18th 2004, 17:10
Frank Frank is offline
Hi,
If you want independent rear suspension, mid engine V8 Beetle check this out
http://www.rorty-design.com/content/beetle.htm
Old December 18th 2004, 20:10
V8 bug
I am trying to keep it as stock looking as possible. I was going to try to use a porshe tranny and stock swing arms. We have a guy that builds custom drive shafts for anything. I haven"t figured out how i am going to hide the v8 in the back seat. I was going to just cover it with some steel panels that have been undercoated to reduse road noise. I need to know how long the porshe tranny is from the mateing surface to the fearward most point. My biggest fear is that i am going to have to extend the bug because i don't want it to far foward. I will be using an electric waterpump. Haven't figured out where to put the radiator. I don't want to put in in the front and have to cut big holes for air. Any help is appreciated.
Mike
Old December 19th 2004, 14:22
Which porsche tranny do you want to use?
