What is your take on this gauge opinion?
I was dilly-dallying around searching for gauge options and discovered this:
http://www.geneberg.com/gauges.htm ... and wondered what everyone thought about this. |
Frightening if it's true, a temp gauge reading of up to 390 to 395 degrees but an actual temp of 700 degrees....
I wish I hadn't of read this thread Rob. |
Well I have read that before. It is a nice sales pitch for the dipstick they sell. In fact I have one but i wired it to triger its own light. The idea of turning on the oil press light and makeing stop to think, Is it no oil pressure or just hot? doesn't sit right with me. You might think it is hot and do nothing for a few seconds while you think. Then the noises you hear while your engine self-destucts will let you know the it was no oil pressure and not high oil temp and You were wrong,,,,,thanks for playing "BERG-Dipstick Roulette"
There are a few places to mount a sender for CHT. The spark plug is the best place to sample the temp, the other type senders will give a much lower reading. This is why they are picking on the CHT guage. The same can be said for the oil temp. senders. you can sample oil temp in alot of places, some will read hotter than others and some will read the temp of stagnet oil(useing a "T" at the press sender). That whole dissertation on guages is there to sell a product, some of it is true. But if you select the proper guage, sender and location you will have a good idea of what is happening in your engine and can see a trend before a light comes on to tell you that you now have a real problem. Remember, even if the guage is a little inaccurate, it still gives you a referance and when you have a change in the referance you know that something has happened and you should take action or monitor the changes. The more information you have the more you know about your engines operation/heath.
Frightening if true, indeed. It just didn't ring right with me, though. That's why I posted it here.
I didn't and don't know about the dipstick gizmo. My only investigations on Gene Berg dealt with a 1776 they supposedly built on a Type 34 I was going to buy (before the seller was "going to throw in $10k worth of goodies for just an extra $4k to complete the deal"), and their shifter which was recommended over a NOS Hurst shifter I had a line on. I hear daily of engines being destroyed by people relying on gauges. Engines being destroyed? Daily? Really? I tested about twenty each of most brands ... and found none without these problems. ... if they provided reliable information I would be selling them to make a profit just like our competition. Twenty of each brand? All bad? That sounds like a reason to offer gauges. What better marketing tool is there than "ours work, theirs don't?" I am an admitted technoklutz, so if the complaint was on CHT gauges, I'd probably have skimmed over it without any critical thought attached. But oil temperature? My '86 GLI had one, and I can't believe VW put in a $250-300 gauge and sender unit on a model like that. Plus I read, Oil temperature gauge readings would be 212 to 220 degrees on the gauge when the true test temperature was 240 to 260 degrees. Where was the "true test" temp taken? I mean it had to be taken at the same time. Was it taken at the same place, too? If so, how? There seems to be a genuine lack of information. And how complicated is it to get an oil temp? I know my way around a kitchen a lot better than an engine bay. There are plenty of fancy and cheap oven and meat thermometers in the market place. Many ovens have hot spots. Meat thermometers have to be placed correctly. Bottom line is most are quite accurate (or I guess it is possible they are inaccurate with nearly identical readings). Oil temp readings can't be that difficult or requiring untold expenditure. Can it? It would seem to me if twenty times however many brands tested gave a certain range of results while the "true test" was giving something different, I would start questioning the "true test." But, I am a technoklutz. So I will let my intuition be up for review. |
Volksworld magazine ran a small temp gauge comparison test in their ‘SUMMER 2001’ issue.
They took a few well known gauges - Autometer, Jaeger and VDO(x2 one made in USA the other Malaysia) Various senders - pressure relief valve plug, sump plug, T piece from the oil pressure takeoff on the ‘case, and a dipstick sender (VDO). The ‘Controlled Test’ consisted of having a saucepan of hot oil on a stove. The senders dipped into the oil. The gauges wired up to the senders. The gauges then had their readings checked against a ‘highly accurate’ (their words not mine) industrial thermometer. This gave them the results of which gauge AND sender unit were the most accurate. Here ya go….. TRUE TEMP 80 90 100 110 122 127 VDO 1 (T-PIECE) 79 90 102 110 123 131 VDO 2 (T-PIECE) 80 85 99 105 120 131 VDO (DIPSTICK) 82 85 100 109 120 130 AUTOMETER 79 85 99 109 121 127 JAEGER 81 90 98 120 130 130+ Now…. None of them are 100% accurate, But then none of them are massively off the mark either, certainly not the huge variation that has been mentioned above. Just my 2 pence/cents |
Aha! (An exclamation, not the band) This confirms my suspicions.
remember, they are called gauges and we refer to things as "gauging them" for a reason. its a relative thing. you will never find one 100% accurate and don't need to as long as you know where there is a swing in temp that you need to be concerned or take action. that said, a mostly accurate gauge is nice.
where you take the reading is as much a factor as the accuracy of the gauge.
