944 front brembo caliper problem
i´ve in my 77´ 1303 cabrio all porsche 944 brakes with a single piston calipers around 4 wheels. i´ve kerscher struts at front with 944T spindles.
The problem is when I go to put the black brembos at the front. in the rear, i only put some spacers to center the caliper in the disc, but in the front.... The Ate caliper mount holes are smaller than brembo´s holes!!!!! what can i do? i know that my spindles are from a 944T but i don´t know year... the disc is mount rear the hubs... i need help please. |
Mounting Dimensions
No expert here, but my understanding is that most of the older Porsches used
3.0" spacing between the mounting holes; But the later Porsches used 3.5" mounting holes. Your Brembo's will be 3.5" spacing between the mounting holes. You can usually fabricate an adapter or you may have to replace your struts with a Porsche 911 type that wil give you the correct spacing. Your could also sell the Brembo's and replace with something else designed for our loved Beetle. Good Luck Allan Note: 1977-1989 Porsches 911 used 3.5" spacing All 914 Porsches used 3.0" spacing
1972 Super |
