Old January 28th 2005, 04:58
MikeR@'s Avatar
MikeR@ MikeR@ is offline
super beetle front disk caliper bracket tech drawing needed
this might sounds petty to you, US folks, but down here in Romania is outrageously expensive to import such single parts as the caliper brackets
I have purchased a 1971 1300 DP Super Beetle - drum brakes; I intend to uprate its engine to 1600cm - so front brake disks are a must.
I managed to get new stock vw brake discs, rebuilt stock vw calipers, new bearings, seals, hoses and I want to manufacture my own caliper brackets.
Unfortunately I couldn't find any technical drawings that would help me to manufacture these brackets. There are other drawings on the net but they imply the use of exotic brake parts such as Citroen Visa calipers - I am not sure if they have the same mounting points as well as the same offset.
Does anyone have such drawing? or willing to make some measurements on an actual part and draw them?
I like the sturdiness of the following part - a safe design.
http://www.i4putt.com/Herman/DiscImages/Image08.jpg
Thank you!
VW 1200 - 1981 - 1200cm - GT Beetle clone - Lemmerz 5 1/2 sport steel wheels, Kamei front spoiler, Golf Mk1/2 tuning
VW 1302 - 1971 - 1300cm - German Look project - in the works
All rear engine cars rule!
www.r-si-r-doctori-in-broaste.go.ro
Old January 31st 2005, 03:18
MikeR@'s Avatar
is my request too modest to be taken into consideration?
Old May 21st 2005, 02:55
LLVWGL LLVWGL is offline
BUMP!!
i need to know about this too. what have you guys used?
is it the same as for a standard? (fab bracket)
