Old February 4th 2005, 19:54
spidy's Avatar
spidy spidy is offline
motors problems
hay aj build a ty4 motors 2.1 and my problem is the motor hew now power.
when aj pus the gas in 1.2and ger to the limit hes sheiking and aj mast sot dawn the motor and then is vorking normal.a dont now what is this.aj hew a elek.start.motor dont hew the power for 2,1ccm aj dont now whay.if sombady now what is the problem plis help my.aj need help.motor is new 10 000km
ajm from slovenia and aj bild the speedstar kabrio
Old February 5th 2005, 07:35
spidy's Avatar
spidy
when I pus the gas in 1.2and ger to the limit hes sheiking and I must shat down the motor and then is working normal.I dont now what is this.I have a elek.start.motor dont have the power for 2,1ccm I dont now whay.if somebody now what is the problem plis help me.I need help.motor is new 10 000km
I m from slovenia and I build the speedstar kabrio
this is my spidy(silver bulet)
Old February 5th 2005, 12:56
i can't be sure what you are saying, but i think you are saying that you are having a loss of power when the engine had been fine. i would search through the ingnition system and ensure all is right there first. check advance, plugs, wires, coil, etc.
Old February 5th 2005, 14:06
spidy's Avatar
spidy
ok.thank you wery much,I will chek and report.
Old February 20th 2005, 08:37
spidy's Avatar
spidy
do anybody know how I set the ingnition sistem on the type4 motor 2,1 ccm
Old February 20th 2005, 11:35
what kind of ingition system are you running?
