Old April 28th 2005, 00:09
Troy_Audio's Avatar
Blinkerz & Hazards On Steering Wheel...
Hey Guys
Yup you got it..
I got board.. Had a lil time on my hands
I ended up going to A Cycle Savlage yard & getting
(1) 1990 Kawi Bar Control + (1) Goofy Idea
I will be working on Cleaning it up But its cool for now
Peace Troy
Old April 29th 2005, 17:08
libila libila is offline
That's different, sweet!
Sort of off topic but how did the install and everything go with your Autometer gauges?
Old April 29th 2005, 18:56
Troy_Audio's Avatar
Well the top button it for the blinkerz & the lower is Haz button..
Plan on doing a mold over it in Molding puddy & cover it in Fiberglass resin..
I think i can make it a bit smaller with some sadering & trimming..
Peace Troy
Old April 29th 2005, 18:59
Troy_Audio's Avatar
Im going to make a new dash from steel
open to dash layout.. the 1 I got sux..
May do Tach/speedo in the center of the wheel & the others in a Console or the radio hole..
May add push button Start & a few cutoff switchs
Peace Troy
http://tinyurl.com/ey48l
Old May 18th 2005, 14:18
rip's Avatar
rip rip is offline
so does the blinker switch move forward and back (wrt the car) or left and right?
Old May 19th 2005, 22:33
Dasdubber's Avatar
Troy did you have much trouble wiring up the hazard switch? I have the watsons kit as well and have one wire from the fuse panel for a hazard switch but no idea how to wire it up (I am using a hazard switch off early 70s beetle - it has a bout 8 spade terminals on it and I have no idea what they are all for!).
Also any trouble wiring your horn up? I know one wire goes to horn (for +ve power) and in the original set up the ground wire from horn was connected to the steering column (63 beetle)....and another wire from horn button to steering coupler. However in the watsons kit there is the green wire for horn +ve but also a black HORN SW wire for horn switch - but I don't know where this one should go!!
Sorry to hijack your thread! How does the audio system sound??
