Old June 13th 2005, 23:03
Doogie S's Avatar
Doogie S Doogie S is offline
Same parts - Different suppliers
Greetings,
Just a questions on 944 trailing arms (before you sign and roll you eyeballs, it's not the usual type)
In a continuing quest to obtain a set of aluminum early 944 arms (more ore less complete) I have come across two different venders who have the opposite arms (one has a left, the other has a right)
Has anyone mixed arms with any problems? I would prefer to get a match set, but if things keep going like they have been, the opportunities seem few and far between.
I'd just like your thoughts on this before I proceed.
Thanks,
Doug
Old June 14th 2005, 00:18
rip's Avatar
rip rip is offline
well I suppose there wouldn't be a problem with two different sources, but maybe someone here nows of a source, guys?
Frankly I'd wait 'til others chime in here, as I have yet to think about getting the porsche arms. I don't even know if the arms had changed through out the years.
but why the 944 arms? given the reason you may want to look at an alternative like eagle or blind chicken racing. I believe they both can custom make some arms out of 4130, which would both be relativly light and strong with an increase in length if need be. This may be a good alternative if you find porsche parts difficult to find in a match.
Old June 14th 2005, 00:20
rip's Avatar
rip rip is offline
here
http://www.eagleperformance.com/NewF...RearTrArm.html
http://www.blindchickenracing.com/Pr...sion_parts.htm
Old June 14th 2005, 03:00
libila libila is offline
I hope I'm not imposing here by asking what the advantages of the 944 trailing arms are?
Old June 15th 2005, 02:30
rip's Avatar
rip rip is offline
they're aluminum lighter
provide larger rear track
easily go with porsche rear brakes
and I think if you want you can adjust them. (how??? don't know)
Old June 15th 2005, 02:50
Does it widen the rear track to the point where one would need wider fenders if using a seven inch wide wheel? Can the 944 arms be added with no other modification (besides brakes)?
Sorry for hijacking your thread.
